2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-12T13:08:43+00:00
    And poorly designed products apparently. They just rushed out to the market since they are getting their lunch handed to them (by pretty much everyone), and this **** is what you get. How about taking a bit of time to MAKE IT RIGHT THE FIRST TIME!!!! Ugggggg!!!! Pathetic at best.
    I want to like MS, but I want a product that actually works even more.
    2013-12-12T13:20:19+00:00
    There hasn't been a Nov driver pack available for download yet unless you back it up from your own system when it was brand new.
