2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
  1. Deleted
    2014-01-20T12:50:16+00:00
    SP2 with the 4200U.  Really love this little machine and power.  First, the December 10 firmware update failed on 12/10, then succeeded on 12/15.  This was before I knew there was an issue with the December 10 firmware.  I had auto updates turned on.  That mistake won't happen again with any of my 3 Win8.1 boxes.
    Initially I did have the battery message and it appeared it wouldn't charge.  However, that only appeared last month the first two or three times I used it after the failed update.  Only issue I have is the sleep/wake issue.  So, now my system is always shutdown.  Waiting for the January firmware update so I can trust sleep when I simply close the cover and walk away.  This is just crazy how it some have received the update and others haven't.  I have the sleep issue and want it resolved.
