2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T01:28:04+00:00
    PC World article at: http://www.pcworld.com/article/2089540/microsoft-releases-update-to-fix-surface-pro-2-firmware-problems.html
    Between that and Wallstreet's observations, the hypothesis I advanced earlier today, to explain why some got the 18 January update and others didn't, doesn't seem to be the explanation.
    "The firmware is available to those who were and were not able to download the initial update, although Microsoft hasn't yet acknowledged the launch on its Surface Pro 2 update website.
    According to ZDNET, the company is sending out the updates in waves, rather than all at once, and more updates may follow."
    http://www.techradar.com/news/mobile-computing/tablets/microsoft-now-rolling-out-its-fixed-firmware-update-for-surface-pro-2-1216599
    2014-01-20T06:20:50+00:00
    Public releases in waves are frustrating for end users.  It's the evening of 20 Jan here - and still nothing new in Windows update.
    Microsoft need to act more like Apple.  i.e. Release pre-release quietly to their MSDN/TechNet users game enough to try it,, and then release to the public when they make the public announcement.
