2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T23:19:19+00:00
    Just as a follow up to my two test Surface Pro 2's:
    SP2 without Dec firmware update was eventually successful in the "current" Jan update (only software, no firmware).  Originally had experienced shorten battery life and crash when put to sleep (where under sleep, it crashed when going into hibernation).  After installing each of the 3 software updates separately and testing each update's effect to the sleep and hibernation, the update took without issue.... so far.
    SP2 with Dec firmware problem took the "current" Jan update without issue.  But still do not see a Jan Firmware fix (East Coast).  I replicate the mysterious "turning on" effect by setting sleep = 1 min and hibernation = 1 min.  I observe the system go to sleep (in 1 min), then wake after 1 minute, where it will remain on.  Thus replicating our mysterious battery drain, hot to the touch systems.
    It seems clear MSFT has a real problem with their Surface Pro devices and Patch Tuesdays (remember, all was great until that one Patch Tuesday in December).  I am doubtful their updates have effected a small population of systems.  I sincerely hope we find resolution soon.  It will be sad to see such a promising technology fail due to updates.  The one positive is that MSFT is replacing units - That suggests a strong commitment.
    2014-01-20T00:16:39+00:00
    PC World article at: http://www.pcworld.com/article/2089540/microsoft-releases-update-to-fix-surface-pro-2-firmware-problems.html
    Between that and Wallstreet's observations, the hypothesis I advanced earlier today, to explain why some got the 18 January update and others didn't, doesn't seem to be the explanation.
