2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T22:23:51+00:00
    how about we shorten this to...
       "When can users expect to receive the 1/18 firmware fix?"
    The hypothesis I'm exploring is that some of us have been offered the 18 January fix and others of us will never be offered the 18 January fix, but everyone will be offered a second fix aimed at some problems not addressed by the 18 January fix.
    I don't know if the hypothesis is correct, but if so there are two questions:
    1.  Should those for whom the 10 December firmware update failed install the 24 October firmware update that is being re-offered?
    2.  When will the fix for the rest of the problems be released?
    I agree that it would be good if Microsoft explained what was going on so we didn't have to do Kremlinology / Talmudic analysis, and it would be great if the journalists on this story had the experience with the Surface, the knowledge of what happened in which configurations, and the technical background to figure out all the best questions themselves, but the reality may be that the best way to figure this out is for us to be actively involved in helping.
    This forum would be considerably more useful if there were an active participant from Microsoft involved.  The same is true for forums dealing with entirely different issues, such as medical issues, but in medicine it is even more rare to have the desired insiders involved.
    You may (and i mean maaaaay) find this helpful. It's about the Oct Firmware update:
    http://global.christianpost.com/news/microsoft-surface-pro-2-software-update-now-available-112952/
    2014-01-19T22:42:15+00:00
    One issue I am still having, is that the battery capacity is inaccurate after going into sleep mode.  I'm finding that the full charge capacity is drifting down as the device sleeps.  I was having this problem after the failed December update.  Seems the updated firmware (which I have received and installed) does not correct this problem.   Hopefully this will be corrected soon.
