2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T19:22:08+00:00
    Official statement from Microsoft included as an update in ZDNET article by Mary Jo Foley:
    http://www.zdnet.com/some-microsoft-surface-pro-2-users-report-a-firmware-fix-rolling-out-7000025324/
    "This weekend we released an update that addresses the unexpected wake and battery drain behavior experienced by a small number of Surface Pro 2 customers who installed the December Windows Update. This should have no impact on users already running the October Windows Update. We’re working hard to address the remaining Surface Pro 2 items from the December Windows Update.”
    2014-01-19T19:40:04+00:00
    Some people got a "Failed" status report for their attempt to install the December firmware update.  Is getting such a message the factor that determines whether or not the January firmware update is offered?
    I got a Failed response to the December update and have not been offered the January update.
    Parsing these Microsoft statements calls upon the skills used in Talmudic analysis and Kremlinology.
