2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T17:51:54+00:00
    If you reintalled W8.1 after the failed December firmware update, will the January fix be available (since the install history doesn't reflect the failed December firmware after reinstalling W8.1)?
    is the update going be available for users who did not install December firmware
    2014-01-19T18:06:00+00:00
    After the Jan firmware update I've changed my power profiles to go to sleep (instead of hibernate), and the sleep seems to be working ok. I had it sleeping the whole night and the battery showed the same charge in the morning.
    Xka.
    My understanding is that closing the Type Cover 2 will put the machine into the sleep mode. Also, if I don't have the Type Cover 2 attached, and the screen turns off, the machine will go into the sleep mode at some point as well. In other words, I don't need to choose the Sleep mode manually from the shutdown menu to induce it. Is this correct?
    To give you an example, last night the battery was 100% full before I closed the lid. This morning, the battery indicator was showing 36%. What's even stranger, after using the machine for a couple of minutes, the battery indicator jumped to 51%.
    You can change the behaviour of sleep modes how you want. I want the surface go to sleep when I close the lid and hibernate when I press the button. I can then shutdown completely from charms, which is not a frequency thing. I don't want it going to sleep/hibernate based on timer.
    You can set also the time it takes to turn of the screen, but this is not same as sleep mode.
    I've also noticed that the battery indicator doesn't show correct values immediately after the wake up, but takes few minutes.
