2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T16:49:50+00:00
    After the Jan firmware update I've changed my power profiles to go to sleep (instead of hibernate), and the sleep seems to be working ok. I had it sleeping the whole night and the battery showed the same charge in the morning.
    Xka.
    My understanding is that closing the Type Cover 2 will put the machine into the sleep mode. Also, if I don't have the Type Cover 2 attached, and the screen turns off, the machine will go into the sleep mode at some point as well. In other words, I don't need to choose the Sleep mode manually from the shutdown menu to induce it. Is this correct?
    To give you an example, last night the battery was 100% full before I closed the lid. This morning, the battery indicator was showing 36%. What's even stranger, after using the machine for a couple of minutes, the battery indicator jumped to 51%.
    2014-01-19T17:17:20+00:00
    Still stuck without a FW update days after MS has pushed to others.  Again, just give us a standalone installer!
    I do NOT want to do ANOTHER reset to get this (and who knows if it would even show up?).
    How about some communication MS? This could be a test roll out.  I've seen OEMs do it for handsets b4.  Then after a few were updated without issue they update all.
    Still, this is making me mad.  Lack of communication!
