2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T11:48:23+00:00
    I'm in the UK. SP2 256GB.
    I had a failed December update, and all the various problems that are described on here. Refresh didn't sort anything out, but I've been managing OK with erratic Wi-Fi and messed up hibernation the main problems.
    Yesterday I saw the October firmware update again (I had already installed it), and let it install again. Now I'm seeing more problems than previously - including battery meter displaying 'plugged in, not charging' and then on restart 100%, and sleep seemingly messed up too.
    I think I thought that the October firmware couldn't do any harm as I had it installed already, and that maybe it was going to install again and then let the January firmware install. Doesn't seem that way. Just seems to provide a new selection of random problems from the menu.
    M/S support had told me the new firmware was coming on 14/1 so I'm not best pleased. They also warned me that there aren't many new 256GB models anywhere, so I'm not sure advance replacement will be ideal either. I don't want to drop down to the 128GB as I want 8GB RAM.
    I could try and return the device as unsuitable (not to M/S, bought elsewhere) - but it's been more than a month now. I actually want the SP2 though. Maybe I'll just return it and wait for the SP3 to come out.
    I'm actually trying to use the SP2 to replace my work laptop and iPad (and pad of paper and pen), so the whole thing is getting beyond a joke now. So much potential, such poor execution in terms of firmware but also in terms of communication. Considering this is the flagship attempt from M/S to move into innovative PC hardware and show what Windows can do, it's not being run very competently.
    2014-01-19T12:51:29+00:00
    Thanks to the two preceding UK respondents.
    Boy, I'm glad I have unchecked the October firmware option.
    And once more (MS are you reading this?) I have never had such problems with firmware/os since I started using Windows (NT 3.5) as a refugee from Mac's crash-o-matic 90s pre os 10.
    A disgracefully insulting lack of concern for Surface purchasers - and we're not even "early adopters"...
    Roy
