2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T10:02:35+00:00
    UK SP2 user.
    Every time I check updates available I see the October firmware update (which failed previously.) I am not seeing any other important updates available although numerous have been installed over the last week or so. I don't allow automatic installation BTW.
    At present I have a working device - although I am currently using it only lightly and mostly on mains power - but I am getting very weary of this nonsense and MS's disgraceful lack of clarification. It's certainly not something I'd rely on for critical mobile use. I surely wouldn't recommend it to anyone.
    What are other UK SP2 users seeing please?
    Roy
    2014-01-19T10:15:30+00:00
    UK SP2 user.
    Roy
    I am the same as you - am gutted by lack of communication from MS & slow fix - which is a shame because I really like the device but cannot live with its erratic behaviour.
    And, am still waiting for the firmware update to appear for my SP2 pro.
