2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T04:55:59+00:00
    Same story - hw update but nothing else after update clean up.
    2014-01-19T07:37:27+00:00
    I bought my Surface pro 2 (256GB) December and installed the failed firmware. My device also suffered from sleep issues, but I switched to hibernate and everything was ok (no other issues).
    Today I received the Jan 18th firmware update (Finland). Even though I had disabled automatic updates, the windows update already asked to restart and had downloaded the firmware. It was about 4.5 MB.
    Also the update wiped my update history, which was wierd. It also installed another update at the same time.
    I have now installed the new firmware, which took two tries, as with first try the computer hanged at restart. It seems that sleep works now, but I have to test it for couple of days to say more.
    Looking from device manager, it seems that some of the firmware drivers date now to December and two to November.
    After the Jan firmware update I've changed my power profiles to go to sleep (instead of hibernate), and the sleep seems to be working ok. I had it sleeping the whole night and the battery showed the same charge in the morning.
    I haven't had a memory card attached, so I don't know if my device has any issues with it.
