2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T02:06:51+00:00
    My settings are not to install any updates automatically and my list of installed dates doesn't include the January SP2 firmware update. There may be some process that has some updates not offered immediately, even when checked manually using the Desktop version of Windows Update.
    2014-01-19T02:47:09+00:00
    After my failed update, the diagnostic tool reports the following:
    https://www.dropbox.com/s/i9bx3kf7gxqxpgl/Screenshot.png
    perhaps these updater issues are stopping windows asking for the new update?
    That would complicate things... some may not wish to go through this, but perhaps a refresh is required?
    Wait wait wait... This just hit me. Those who haven't received the Jan Firmware Fix, before jumping to conclusions and refresh your devices, have you noticed whether your system received any Definition Updates of late? If so then probably your Windows Update routines aren't effected. But if not, I remember during one of my 8 resets, I pulled a Dylan Tullberg's maneuver, a maneuver which wasn't designed to be performed after a reset and the updater completely died. If that's your scenario, reset.
