2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-19T00:57:13+00:00
    After my failed update, the diagnostic tool reports the following:
    https://www.dropbox.com/s/i9bx3kf7gxqxpgl/Screenshot.png
    perhaps these updater issues are stopping windows asking for the new update?
    That would complicate things... some may not wish to go through this, but perhaps a refresh is required?
    2014-01-19T01:32:05+00:00
    Here's an inkling of how long you might have to wait for the 1/18/14 SP2 firmware update.
    I have a Surface RT.  Everyday I manually check for updates.  Just this evening (1/18/14) I get notice in Windows Update that there is a 1/15/14 firmware update now available for my Surface RT.
    So it may be that the SP2 update is still several days down the road for some of us.
    EDIT: Turns out that I got the notice but the firmware update was already installed on 1/15/14.  So Microsoft seems to have a little problem with Windows Update reliably determining and reporting to us Update status.  Previously others have mentioned being repeatedly offered earlier updates for SP2 even when installed.
    So maybe it's Microsoft SNAFU's not necessarily us individually that's affecting whether Windows Update reliably reports the availability of the 1/18/14 update to us.  Maybe MS has a problem not only with the product being delivered but its delivery system??????
