2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T23:50:30+00:00
    Still no firmware update ... -.-
    2014-01-18T23:59:51+00:00
    Me either.  And last night I blew it and forgot to hibernate and ended up with with a hot pro 2 this morning.
    Hurry up ms
