2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T21:21:49+00:00
    Hi from the SP2 high CPU forum... over there it seems this error only occurs with the i5-4200 CPU. Does anyone have this problem with CPU running high while MicroSD card inserted on the i5-4300 after Jan 18th 2014 update?
    2014-01-18T22:17:26+00:00
    An article http://www.theverge.com/2014/1/18/5307680/surface-pro-2-firmware-update-january-2014 says "Microsoft is re-releasing its latest Surface Pro 2 firmware update today. Following issues with the update last month, the software maker pulled it to investigate and correct the problems. Initial reports revealed failed installations and battery issues in instances where the update was successful. Today's firmware update appears to replace the existing version released in December, and is being offered to systems with or without the previous version. "
