2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T19:50:14+00:00
    I'm in Upstate NY-no update here yet. When (and if) it shows up, I will be waiting to install until more people share their experience with it.
    2014-01-18T20:46:56+00:00
    I am in northern California-- pro2 --got the update yesterday afternoon--have not installed yet
    Jack
    It's very simple. If your are lucky owner of Surface 2 or Surface Pro then you can get and install the January firmware right now. If you have Surface 2 Pro then just wait few days and will be happy too. No matter where you are.  Just get on with it.
