2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T19:25:48+00:00
    As I can see in MS update history, they issued January 6 release for Surface 2 and January 15 release for Surface Pro. Nothing for Surface 2 Pro yet. Also you could read this one http://winsupersite.com/mobile-devices/microsoft-surface-firmware-updates-january-2014/
    Latest release avaliability does not require prior October firmware installation. I've installed October firmware on my SP2 Pro and no January update still now.
    From the posts here, I count 6 SP2 users who got the January firmware, 11 SP2 users who didn't (including me), 12 others for whom their hardware wasn't specified in their posts in the past day (1 who got the January firmware, 11 who didn't).  So I don't see a clear trend.
    I don't see anyone who had a pending October update and got the January update, but it looks like there were just two of us so it is not statistically meaningful, even using Bayesian criteria.
    I imagine the numbers will change a lot over the next 24 hours.  I did get an Update for the English Input Personalization Dictionary for Windows after my first update check today, so updates of some sorts are flowing.
    Still no Jan update here.
    2014-01-18T19:35:56+00:00
    I am in northern California-- pro2 --got the update yesterday afternoon--have not installed yet
    Jack
