2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T17:20:10+00:00
    Nothing in Spain , sp2 128g with  october firmaware installed ... I think mine will be a 19-Jan firmware update ... with luck, its 18.20 pm here.
    2014-01-18T18:19:21+00:00
    Does the availability of the latest version require prior installation of the October release?
    Could someone post the KB number of these releases when they arrive. Why does the update check no longer enable us to see the number of the patch???
    As I can see in MS update history, they issued January 6 release for Surface 2 and January 15 release for Surface Pro. Nothing for Surface 2 Pro yet. Also you could read this one http://winsupersite.com/mobile-devices/microsoft-surface-firmware-updates-january-2014/
    Latest release avaliability does not require prior October firmware installation. I've installed October firmware on my SP2 Pro and no January update still now.
