2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T16:16:24+00:00
    I am in UK too. October firmware update listed as still available (my installation failed and I haven't got the nerve to try it again) but no January version listed yet.
    Does the availability of the latest version require prior installation of the October release?
    Could someone post the KB number of these releases when they arrive. Why does the update check no longer enable us to see the number of the patch???
    Roy
    2014-01-18T16:41:04+00:00
    I bought my Surface pro 2 (256GB) December and installed the failed firmware. My device also suffered from sleep issues, but I switched to hibernate and everything was ok (no other issues).
    Today I received the Jan 18th firmware update (Finland). Even though I had disabled automatic updates, the windows update already asked to restart and had downloaded the firmware. It was about 4.5 MB.
    Also the update wiped my update history, which was wierd. It also installed another update at the same time.
    I have now installed the new firmware, which took two tries, as with first try the computer hanged at restart. It seems that sleep works now, but I have to test it for couple of days to say more.
    Looking from device manager, it seems that some of the firmware drivers date now to December and two to November.
