2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T16:00:37+00:00
    You may have to install the October update to get the January update to show up.  I installed the October update yesterday and got the January update yesterday.
    I also wondered whether you need to install the October update to get the January update.  But since many people haven't been offered the January update yet, I'll wait a day or so until a larger fraction have been offered the January update to see whether not getting the January update yet is random or related to the October update status.
    But the experiences with the January update sound positive so far.  I don't know why Microsoft delayed the January update for 4 days, but if that was the difference between a good experience and a bad experience, the delay was a good decision.  They could have been more communicative, though.
    2014-01-18T16:15:08+00:00
    So far, my 128gb Surface is now back to normal.  It sleeps properly, does not wake up on its own, and goes into hibernate as it should.  I think, at least on the issues I had, the problems are resolved.
    Not sure why the rollout seems staggered, but maybe they are doing that intentionally in the event there is a problem.....
