2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T14:46:09+00:00
    No 18 January update for me yet (USA) even when I proactively check for updates.
    The 24 October update is still being offered, but I haven't re-installed it (I had installed the 24 October and 10 December updates when they were released).
    I knew that different computers got notified of updates at different hours due to the different update checking timing on individual computers, but in addition there seems to be a difference in what you are offered if you check proactively.
    You may have to install the October update to get the January update to show up.  I installed the October update yesterday and got the January update yesterday.
    2014-01-18T14:59:13+00:00
    I bought my SP2 256 / 4200 on Dec 6, 2013 and made an Acronis True Image at once before changing anything. Later on ran fully into the Dec 10-trap.
    No Firmware update in Germany yet, 15:56 CET.
    Made a recovery from Dec 6 image (unfortunately, doesn't change the ROM :-(), and again, no Firmware update. So resetting doesn't seem to help to get the update sooner.
