2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T14:34:09+00:00
    No firmware here either Minnesota 8:30 am CST SP2 128 GB
    2014-01-18T14:44:06+00:00
    I got it for  my 256gb sp2 4200 around 9am NY time.
