2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T10:26:08+00:00
    No update for me yet (Germany).
    Does the update require a reboot?
    SP2 128 4200U
    Yes it's a ROM flash, done at the Surface logo screen.
    2014-01-18T13:34:27+00:00
    No 18 January update for me yet (USA) even when I proactively check for updates.
    The 24 October update is still being offered, but I haven't re-installed it (I had installed the 24 October and 10 December updates when they were released).
    I knew that different computers got notified of updates at different hours due to the different update checking timing on individual computers, but in addition there seems to be a difference in what you are offered if you check proactively.
