2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T10:18:43+00:00
    No update for me yet (Germany).
    Does the update require a reboot?
    SP2 128 4200U
    2014-01-18T10:19:36+00:00
    No update from US 128 SP2, but located in Spain ATM. I'll check at another time.
