2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T09:52:20+00:00
    Just got Firmware update, 18/01/2014 installed successful, switching to sleep. So far so good, no wake up, will report back latter. Ireland.
    2014-01-18T10:03:06+00:00
    I have the firmware update available (18 Jan).  It's a small file though... less than 5mb.
    I'm not going to install it quite yet.
    I have the 256gb SP2 (Australia) and have the October firmware installed.
