2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T09:18:00+00:00
    No new firmware yet arrived- Germany as well.
    SP2/256 4200
    So I will wait and not bring the SP2 back to MediaMarkt...
    Though I suffer from all the Problems that are told here.
    2014-01-18T09:19:00+00:00
    I am also in NSW Australia and I do not see a firmware update. those who are, what version of SP2 are you using? 64G, 128G, 256G or 512G?
    No update in Spain .SF2 4200 128gb with problems by december firmware and octuber firmware installed now.
