2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T08:12:39+00:00
    I am also in NSW Australia and I do not see a firmware update. those who are, what version of SP2 are you using? 64G, 128G, 256G or 512G?
    2014-01-18T08:16:38+00:00
    Got the update here in Germany. but high CPU issue with sd Card still not fixed.
    SP2/512 4200
