2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T04:10:19+00:00
    Hello Phra,
    This is a very good idea, I post in the twitter of panos_panay too, if all the users in this thread write in te panos_panay twitter I think Microsoft can hear easily.
    Thanks Phra for the idea, all the other users tweet in panos_panay twitter.
    See you.
    NSW Australia. Just installed the Jan-18-2014 Firmware Update on a SP2 out of the box. Wifi, Bluetooth, pen & Type Cover 2 all functioning well. No unknown devices in Device manager.
    An old problem still remains: Cold booting with MicroSD card (SanDisk Ultra 64GB) inserted still causes "System" (NTOSKRNL.EXE) and "System Interrupts" to constantly hog the CPU. The "System" consumes of 10-13% CPU while "System Interrupts" chews another 8-9%. Manually ejecting the card prior to every cold boot -or- putting the tablet to sleep then wake it back up will temporary fix this issue.
    Still looking into Sleep & Shutdown issues, will report back if any.
    I'm also in NSW Australia, but I'm not seeing any 18/01/2014 firmware update on mine. Wondering do you have the 4200 CPU? or the 4300 CPU? Not sure why I'm not getting the 18/01/2014 firmware.
    Anyone else from the down under confirm?
    2014-01-18T04:42:13+00:00
    Hello Phra,
    See you.
    I'm using the 4200 CPU.
