2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T01:25:23+00:00
    Hello, I am installed new firmware 1/18/2014, sleep mode working, but I need much time to see the awake problem and battery drain.
    Surface Cover Telemetry issue still appear in uknown divices, but I work perfectly with my type cover 2, I don't know what is the function of this driver.
    I am in Colombia and here is 17/01/2014, please recheck de updates.
    Regards
    2014-01-18T01:37:50+00:00
    Jim, I got an upgrade and I am in California.
