2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T00:38:11+00:00
    I'm only showing the 10/24 firmware update, nothing newer.
    BTW, I've installed the 10/24 firmware updated several times, each time it's listed as "successful" in the update history, yet it keeps showing up saying it needs to be installed again.
    Anyone know why?
    Thx!
    I just got a new firmware update... installed and no problems yet.  Dated 1/18/2014.
    Update - sleep and hibernate seem to be working now.....
    2014-01-18T01:18:21+00:00
    No update here in the U.S. where it's still 1/17/14.  Maybe it's a "rolling" update and it only appears once one's system clock turns to 1/18/14?  (they're using you Aussie's and New Zealanders and other folks in the Eastern part of the world as guinea pigs! - <<<just kidding>>>.
