2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-18T00:24:25+00:00
    Just received the firmware update for Surface Pro 2. Anyone installed it yet? If so, any issues?
    2014-01-18T00:31:53+00:00
    I'm only showing the 10/24 firmware update, nothing newer.
    BTW, I've installed the 10/24 firmware updated several times, each time it's listed as "successful" in the update history, yet it keeps showing up saying it needs to be installed again.
    Anyone know why?
    Thx!
