2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-17T19:50:15+00:00
    The problem with the Power Cover is that it dumps its charge into the Surface Pro.  So as long as the Power Cover has charge, it's going to be keeping the Surface Pro (2) battery at 100% charge.  Running a Li-ion battery at 100% charge is not good for the long-term life of the battery.  The battery will last longer if kept most of the time at an intermediate charge (20% to 80% seems to be the general rule) and Apple recommends a stored device be kept at 50% charge.  So if utility rather than money and device longevity is most important, the Power Cover will be great.  But if you want to make your expensive device's irreplaceable battery last a long time, it's not such a good idea unless Microsoft includes software/firmware to control power flow from Power Cover to Surface Pro.  Anyone want to bet that they are smart enough to do this, especially given firmware nightmares described in this forum?
    The general issue of trading usable battery capacity on a daily basis for long term battery longevity is described nicely in the following surfaceforum post.  The poster points out that Lenovo and Sony both offer battery management utilities for their devices that allow you to control maximum charging while running on AC and/or even switch off charging and allow your device to run directly on AC without trying to pump more juice into the battery (power switching device might require room and add weight to device....).
    http://www.surfaceforums.net/forum/microsoft-surface-general-discussion/6909-optimizing-battery-health-surface-pro-2-a.html
    2014-01-17T20:39:11+00:00
    I was looking at purchasing the Surface Pro 2 (256GB) model from MS's online store.
    Perplexed as to why every model of the SP2 has been sold out, I did some digging and discovered this firmware issue.
    It appears Microsoft has been aware of this issue since at least December 19, 2013, and there is still no fix, nor any statement from Microsoft as to how they intend upon resolving the problem.
    Is there something I am missing?
    In what universe does Microsoft think this is appropriate?
    I would not buy - save yourself a lot of grief - at least until MS fix the firmware - as this device is not stable. It would be a fantastic tablet - but is let down by poor firmware & show response to fix it.
