2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-17T17:23:22+00:00
    SP1's at 599 are a great deal.  My 17" hp g7 was a great deal at $250, but a tablet form factor with stock 8.1 pro, SSD, touch, pen, and an i5 for just $320 more (with Discover CashBack) would have been awesome.  The forthcoming Power Cover (which I will be buying anyway) will effectively obliterate any difference from the SP2.  If I hadn't bought this laptop and a number of other tablet "deals" I might have had Surface Pro's in the backpack and in the kitchen.  $569 (after rewards) is the sweet spot.
    2014-01-17T19:29:53+00:00
    I was looking at purchasing the Surface Pro 2 (256GB) model from MS's online store.
    Perplexed as to why every model of the SP2 has been sold out, I did some digging and discovered this firmware issue.
    It appears Microsoft has been aware of this issue since at least December 19, 2013, and there is still no fix, nor any statement from Microsoft as to how they intend upon resolving the problem.
    Is there something I am missing?
    In what universe does Microsoft think this is appropriate?
