2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-17T14:42:05+00:00
    I'm still experiencing the battery drain with over heating from the December update.
    Left my surface pro 2 on sleep overnight, and it drained 80% of battery and was burning hot this morning with no response to any button. After cooling somewhat, it finally started charging and starting up. I'm now considering whether this battery drain/burning temperatures is damaging the hardware, specifically the battery. And I will probably seek a exchange for a newer one in the store.
    We will be interested to hear how that goes for you.
    Are you within the 30 days or are you doing a warranty switch?
    2014-01-17T15:08:08+00:00
    I purchased the 2 year Microsoft complete warranty so I have 2 switches for accidental damage. However, last time I had a battery issue, they just gave me a new SP 2 without using any of the 2 switches, since it doesn't count towards accidental damage if its their own hardware/software damage issue.
