2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-17T07:10:05+00:00
    I find annoying the email that I just received from Microsoft for a Surface Pro 2 128 GB  for $300 off!
    Ah.....   The e-mail that I got said "Surface Pro," not "Surface Pro 2.......".  Try reading it again and see if the former is not what's in your e-mail, too.  I think that MS is intent on getting rid of the last of the original SP's.  If they've been sitting on shelves all this time, their batteries are aging, too, so it won't be like getting one hot off the assembly line, besides the other obsolescence factors growing with every passing month.
    "$300 off
    Surface Pro
    Get the device that’s a tablet and a laptop
    for only $599."
    (tried to paste the picture out of the e-mail add and I got "Your message is too long..... Current count is 127,821 characters....."
    So to include a picture, you have to reduce the pixel count so that the characters are below 60,000??  Does each pixel count as a character?  I used OneNote Screen Clipping and tried to paste from that.)
    2014-01-17T11:45:15+00:00
    Don't know about everybody else, but I found that:
    1. Cold Booting a SP2 factory firmware with an SD-Card inserted meant having "Client Runtime Server" csrss.exe hogging up CPU, lagging battery draining system, and a SP2 hot to touch. A sleep or restart fixes this temporarily :(
    2. On the other hand, cold booting an SP2 with Oct 24 Firmware installed (and with SD card inserted) would lead to "System + System Interrupts" running high but not as bad as csrss.exe in point 1. Again a sleep or restart fixes this temporarily :(
    Absolutely annoying.
    I have the same problem and perhaps this problem may affect adversely battery life and computer speed.
    For this reason I don't use the 2 MicroSD that I have bought for my surface pro 2. (64GB  54.41 Euro + 32GB  24.16 EURO = about 106 USD)
