2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-17T06:39:54+00:00
    I just received my replacement after 1 week of waiting, after sending mine out.  I was told in my conversation it would be a new unit and that it would have the newer version of the processor.  What I got was a individually bagged refurb unit with the same original 4200 processor.
    Sorry to hear that.
    So, new strategy now:
    1. Call in the Support Request (SR) ticket.  You might need to run a few worthless tasks on the first try.
    2. Then follow up the SR with another call after nothing changes (because it won't), and then get a warranty exchange set up with the Rep.
    3. Don't mail it in or do an Advanced Exchange.
    4. Tell the rep that you just want to swap at the store.  If you don't have a store nearby, this is a good excuse for a trip.
    5. At the store, you can examine their stock of 256's or 128's for Lot #'s that are higher than 1350.  512's are not popular enough to have run through their stock of the old CPU.
    6. Go home with a Lot 1351 or higher.  The higher the better.
    7. Before connecting to wifi, turn off auto updates.
    8. Apply all of the updates up to and including the first Oct. 24 firmware update.
    9. Stop applying updates and enjoy!
    Optional: monitor these boards for news that firmware updates are again stable, so you can hopefully re-enable auto updates.
    Good points.   Except I don't agree with you regarding the Oct 24 firmware update.  You'd have to do some serious convincing there.
    Don't know about everybody else, but I found that:
    1. Cold Booting a SP2 factory firmware with an SD-Card inserted meant having "Client Runtime Server" csrss.exe hogging up CPU, lagging battery draining system, and a SP2 hot to touch. A sleep or restart fixes this temporarily :(
    2. On the other hand, cold booting an SP2 with Oct 24 Firmware installed (and with SD card inserted) would lead to "System + System Interrupts" running high but not as bad as csrss.exe in point 1. Again a sleep or restart fixes this temporarily :(
    Absolutely annoying.
    2014-01-17T06:52:34+00:00
    I find annoying the email that I just received from Microsoft for a Surface Pro 2 128 GB  for $300 off!  IE, instead of the $899 which we early-birds paid (not me, I paid even more; I got the 512 GB)... but now it's only $599.  Now what does that tell you?
    I thought they were oversold out of their Presales which were reserved until June 2014, but sold out by Dec 2013.  Now they drop the price of their product $300?  Is there something wrong?  Or, do they already have the next latest greatest now ready for release?  Hmmmm.....
    Meanwhile, the Dec 10th firmware glitch is met with mushroom treatment... kept in the dark and fed B.S. (politeness for the board)
    Nevermind me... just grumbling.
