2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-17T06:17:35+00:00
    Thats the problem, my one would boot itself up after doing a shutdown.
    It would just start itself, I could have it sitting right next to me after doing a shut down and an hour later it would just boot itself up and keep running.
    That is why the issue is major in my book, if you have it in a bag and it boots itself up gets really hot then it can start a fire, the so called safe guards to shut it back down after gettting to hot did not seem to work on mine.
    That's why I found that keeping mine "Plugged into Power" AT ALL TIMES was the only way to avoid that issue.
    2014-01-17T06:27:37+00:00
    Moderators of this forum (Steven_B, Hugo_V, TimHogg and Tony_Du),
    You have here an incredible thread with a 594 replies and count every day without an official Microsoft answer, this is the class of support for the buyers of surface pro 2?? Where is the respect for your costumers?
    The people needs any answer of Microsoft, we wait a lot of time and microsoft silence is the worst part.
    I don't want replace my machine, this cost a lot of my time and effort, how much money Microsoft lose with the replacements?, a lot of machines are out of stock even for the replacements, and worst, what is the image for your costumers and the image of your product?
    We only want answers and dates to wait new firmware, No the one month Microsoft silence!
    Thank you.
    The replacement may likely be a refurbished... but it would get you up and running.  Back everything up to a drive (individual files and also the image if you can).  I restored by individual files... did my settings via Skydrive, and just reinstalled software and it was back "up" in less than a day... and I had nearly 250 GB used of my 512 GB SP2.  I think if they can't honor us with an answer, you might as well get back up and running... just swap it out!  (Please post the serial number of the one you are returning along with how hot or what specific damaged it had... so we can support one-another ... like when the next guy receives your bad Surface as his refurbished replacement.  Knowledge is power.)
