2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-17T06:10:06+00:00
    Today I received my new surface pro 2 for exchange.
    It offers me a system firmware update from 24.10.2013. It's 29.0 MB.
    It is the faulty one?
    It's still the 4200U ...
    I researched earlier posts about the 24.10.2013 firmware update and some users reported that their wireless connection no longer functioned.  I can attest that when my original SP2 updated... it did both the 24.10.2013 and the Dec 10th updates at the same time.  My first issue was I lost internet and had to do a REFRESH to restore it.  It cost me all my applications!  Be forewarned!  I wouldn't install ANY FIRMWARE AT ALL from Microsoft until they announce it officially as addressed and FIXED!!!!  IMHO.
    PS.   I received a 4200U... refurbished :(  too.
    2014-01-17T06:15:31+00:00
    I just received my replacement after 1 week of waiting, after sending mine out.  I was told in my conversation it would be a new unit and that it would have the newer version of the processor.  What I got was a individually bagged refurb unit with the same original 4200 processor.
    Sorry to hear that.
    So, new strategy now:
    1. Call in the Support Request (SR) ticket.  You might need to run a few worthless tasks on the first try.
    2. Then follow up the SR with another call after nothing changes (because it won't), and then get a warranty exchange set up with the Rep.
    3. Don't mail it in or do an Advanced Exchange.
    4. Tell the rep that you just want to swap at the store.  If you don't have a store nearby, this is a good excuse for a trip.
    5. At the store, you can examine their stock of 256's or 128's for Lot #'s that are higher than 1350.  512's are not popular enough to have run through their stock of the old CPU.
    6. Go home with a Lot 1351 or higher.  The higher the better.
    7. Before connecting to wifi, turn off auto updates.
    8. Apply all of the updates up to and including the first Oct. 24 firmware update.
    9. Stop applying updates and enjoy!
    Optional: monitor these boards for news that firmware updates are again stable, so you can hopefully re-enable auto updates.
    Good points.   Except I don't agree with you regarding the Oct 24 firmware update.  You'd have to do some serious convincing there.
