2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-16T18:49:09+00:00
    Thats the problem, my one would boot itself up after doing a shutdown.
    It would just start itself, I could have it sitting right next to me after doing a shut down and an hour later it would just boot itself up and keep running.
    That is why the issue is major in my book, if you have it in a bag and it boots itself up gets really hot then it can start a fire, the so called safe guards to shut it back down after gettting to hot did not seem to work on mine.
    2014-01-16T19:15:06+00:00
    From where do you know that it is refurbished?
    I also received a "new" one but it still has the 4200U cpu.
    It came without any accessories. It's only the tablet.
    It was in plastic (as a new one) and I can't see any signs of use.
