2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-16T18:08:26+00:00
    I just received my replacement after 1 week of waiting, after sending mine out.  I was told in my conversation it would be a new unit and that it would have the newer version of the processor.  What I got was a individually bagged refurb unit with the same original 4200 processor.
    Needless to say, I am disappointed and a bit annoyed about all of this.  I don't expect to be told one thing and then given another, days after the timeline for return.  I use this device for work and just got a refurbished unit that I am unsure I can trust any more than the one I sent back.
    This is really bad form, MS.
    2014-01-16T18:39:44+00:00
    Sorry to hear that.
    So, new strategy now:
    1. Call in the Support Request (SR) ticket.  You might need to run a few worthless tasks on the first try.
    2. Then follow up the SR with another call after nothing changes (because it won't), and then get a warranty exchange set up with the Rep.
    3. Don't mail it in or do an Advanced Exchange.
    4. Tell the rep that you just want to swap at the store.  If you don't have a store nearby, this is a good excuse for a trip.
    5. At the store, you can examine their stock of 256's or 128's for Lot #'s that are higher than 1350.  512's are not popular enough to have run through their stock of the old CPU.
    6. Go home with a Lot 1351 or higher.  The higher the better.
    7. Before connecting to wifi, turn off auto updates.
    8. Apply all of the updates up to and including the first Oct. 24 firmware update.
    9. Stop applying updates and enjoy!
    Optional: monitor these boards for news that firmware updates are again stable, so you can hopefully re-enable auto updates.
