2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T23:33:15+00:00
    Any chance to get the drivers pack ?
    Please msft...
    2013-12-12T00:18:39+00:00
    Thanks.  I followed Dylan Tullberg's steps with success (davidb1234's post on p.5 of this thread appears to be a shorter, quicker version of the same advice).
    The System Files Cleanup under Disk Cleanup took forever for me and never really completed officially.  I closed out the Disk Cleanup windows, rebooted, ran the same cleanup steps again and found that although the dialog never provided a successful closeout, the files themselves had been cleaned out.
    Ran Windows Update after rebooting per Tullberg's instructions.  Got a 435 kb Hardware Update, which succeeded.
    Looking at the driver version info listed in Howard S.'s post on p.1 of this forum, all the driver versions seemed to check except for the Type 2 Cover Firmware Update under Human Interface Devices in Device Manager.  The version # listed there is 2.0.226.0, from 10/23/2013 but the version number listed in Howard S.'s post is v2.0.266.0.  However, after the successful 435 kb hardware date, I still have the same version number and 10/23/2013 date for the TYPE 2. Cover Firmware update (same as just after the failed update on 12/10/13.
