2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-16T15:39:58+00:00
    I also have the same problem, have had it since the firmware update in December and what is even more infuriating than the botched update is that there is no roll-back option (other than a Windows refresh, which would involve re-installing all non-metro applications), and no communication from Microsoft.
    Unacceptable for such an expensive product, particularly one which is meant to be Microsoft's 'Showcase' of Windows 8 and their ecosystem.
    Poor form.
    2014-01-16T15:40:30+00:00
    Exactly the same - I've been waiting very patiently - Last time I used it was just after the update - I packed it in my hand luggage while on board  an aircraft flight.  Got to the destination went to use the SP2 and it was red hot and the battery flat
    • useless.  Could have been worse I suppose with a fire on the aircraft.  So much for turning off all electrical equipment during takeoff and landing as well!!
    I've not been able to use it since - was going to return it but the fix is always a day or 2 away and it will take me a day to reinstall the apps and configure it.
    Not very happy - It was a very expensive personal purchase - not a company purchase.
    If nothing by Next Tuesday I will return it. - Its useless as it is as I can't take it anywhere which is why I bought it.  Back to using the iPad with remote desktop.
    Jon
