2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-16T14:36:10+00:00
    Today I received my new surface pro 2 for exchange.
    It offers me a system firmware update from 24.10.2013. It's 29.0 MB.
    It is the faulty one?
    It's still the 4200U ...
    2014-01-16T14:36:54+00:00
    I had to reinstall programs, since I had not done an 'image' backup... I didin't trust what Microsoft had done, so I figured a clean install of software was the best way to go.  It all went quickly.  The SP2 rocks. (when it works)
    I was wondering about restoring from a disk image, but I agree that there are potential issues with bringing over some of the problems from the previous computer.  I'm not an expert on hardware and operating system issues, but my understanding is that firmware updates are not on the disk image.  However, some drivers are involved so I wouldn't be surprised if some of the material associated with the firmware update results in changes in the disk image.
    I'm one of those affected in only a minor way (power drain when type keyboard attached) and I immediately went into hunker-down mode (avoid sleep and hibernation, disconnect keyboard when shutting down, no SD cards) so I'd rather wait days or weeks until Microsoft fixes this rather than take the chance of a disk image restore to a new computer or configuring a new computer the way I like it.
    But I agree that Microsoft's response has not inspired confidence.  I wonder whether senior management has been deluded into thinking this affects only 0.3% of users.  With so many people getting replacements, they should have enough information to know that claim is wrong.
    Microsoft should issue a statement as to what is going on.  It is hard to tell whether they are stonewalling or senior management doesn't understand the seriousness of the situation.
