2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-16T05:06:16+00:00
    I was told today that I could expect my new SP2 to be in no earlier than tuesday next week. Went back to the retailer and told them no i am sick of waiting I want my money back and they can sort it out with microsoft.
    Got my money back and went across the road and hot a HP split that was on sale.
    Sorry MS you have lost a surface pro 2 customer and I don't think i will ever get another tablet from you again.
    Now i just have to sell the type cover etc.
    2014-01-16T07:27:28+00:00
    It took a bit of time to get it reloaded, but it works well.  It was a heck of a lot easier to setup because with Skydrive and my Microsoft account, it remembered a lot of my settings and configurations.  I just had to reinstall my software, printer, and my files.  It is humming nicely.   (Fingers are crossed that it stays that way!)
    If one gets a replacement of the same model, and has a hard drive backup, can you restore onto a new computer from the hard drive backup?  I could imagine that working or failing - I just don't know if it is that easy.
    Yes.  With the USB 3.0 it loaded fast.  I had some of my settings, and apps on Skydrive, and my documents on hard disk.   I had to reinstall programs, since I had not done an 'image' backup... I didin't trust what Microsoft had done, so I figured a clean install of software was the best way to go.  It all went quickly.  The SP2 rocks. (when it works)
