2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-16T04:13:15+00:00
    My SF2 purchased after the Dec firmware fail (and thus unaffected by the Dec problem) has a new problem with the Jan update.  Setting set to sleep after x minutes then hibernate after y minutes.  Upon wake after x+y minutes the system wakes as if it was shutdown - thus losing my last image of work.  I'm guessing a workaround of putting it directly to hibernate might avoid this problem but I'm tired of finding workarounds.  Note, tried vol up + power button reset to see if that would fix issue.
    Performed system restore to just before Jan update.  Problem goes away.  Very discouraging.
    p.s. I also found my battery expected life appeared lower (on average) after Jan update. Again, that issue has also resolved itself after restore.
    2014-01-16T04:49:54+00:00
    So what are we updating for?
    Hmm??
    You don't know?
    Give up?
    Okay, here's the answer...
    To achieve both Micro and Soft states.
