2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-16T03:29:20+00:00
    2014-01-16T03:37:18+00:00
    I contacted Microsoft support tonight and they are sending me a replacement SP2 since mine is perpetually thinking the battery is on the verge or dying despite being fully charged.  As soon as I unplug it, the SP2 will go into hibernation.  I cannot get it back on unless I plug it in again.
