2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-15T23:38:57+00:00
    It took a bit of time to get it reloaded, but it works well.  It was a heck of a lot easier to setup because with Skydrive and my Microsoft account, it remembered a lot of my settings and configurations.  I just had to reinstall my software, printer, and my files.  It is humming nicely.   (Fingers are crossed that it stays that way!)
    If one gets a replacement of the same model, and has a hard drive backup, can you restore onto a new computer from the hard drive backup?  I could imagine that working or failing - I just don't know if it is that easy.
    2014-01-16T00:38:09+00:00
    Oops!  Since the 1/14/14 Patch Tuesday updates my SP2 now seems to be coming on regularly even after shutdown.  Did not do this after my 12/10/13 rescue attempts......   Anyone else have new problems after the 1/14/14 updates?  Last night my unit came on about once per hour for about 10 minutes each time before becoming SUSPENDED again for ~another hour.  The SP2 was zipped tight in its case but the room temperature was ~55 deg F (13 deg C)-winter here and we turn off the heat at night- so hopefully the unit did not overheat.  Unit was shutdown in Airplane Mode via "Shutdown /p" at Admin Command Prompt.  Today it seemed well-behaved for a few hours when shutdown but spontaneously came on when shutdown via the Power icon button available via the Charms settings menu.  Haven't tried Hibernate yet.....  And I thought I had recovered from the 12/10/13 firmware perils.......
    Interesting if Microsoft is going to generate a whole new round of problems by issuing further software/driver updates without fixing the 12/10/13 firmware problem.  Hope the supposed fix comes soon and my SP2 will be gathering dust outside its bag until then......(to overheat when the vents become clogged! - any recipe for cleaning SP2 vents?  Power up the fans to full blast and have them blow everything out????)
