2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T22:55:39+00:00
    I've also found that the firmware update did not install correctly. Unfortunately, davidb1234's suggestion did not resolve my issue. All it appears to have done is cleared the update history.
    2013-12-11T23:15:52+00:00
    I followed the steps and it seems to have fix this issue, the only thing I noticed is that instead of Firmware update, now is shows as Hardware update, I guess its the same thing
