2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-15T21:25:30+00:00
    Swipe in from the Right to get Charms > SETTINGS
    at the bottom, tap > CHANGE PC SETTINGS
    on the PC SETTINGS page
    at the bottom
    tap > UPDATE & RECOVERY
    tap > WINDOWS UPDATE
    then
    first, I recommend to consider selecting >
    CHOOSE HOW UPDATES GET INSTALLED dropdown window
    > CHECK FOR UPDATES BUT LET ME CHOOSE WHETHER TO DOWNLOAD AND INSTALL THEM
    second tap >  VIEW DETAILS
    (UN-Check anything you don't want installed)... it lists updates by type including FIRMWARE
    third  tap >  VIEW YOUR UPDATE HISTORY
    (You can always copy/paste the update number into a search engine to get more specifics, too.)
    2014-01-15T21:27:30+00:00
    Hi Microsoft Team
    First off I love my Surface Pro 2 - it is a fantastic machine... that was until December.
    The December firmware update tried to install 3 times and failed.  I was travelling overseas and outside of my normal routine so did not even know this had occurred.
    However, the day it failed my colours on my screen began to appear dithered.  In the blacks of photos highly pixelated gradation now appeared.  As I am a photographer and use my Surface Pro 2 heavily for editing photos so this is really not acceptable.  It looks like the colour had turned into 16 bit colour.  I dived into the graphics settings and could not seem to change anything that would fix it - nor could I update the graphics drivers.
    The other major issue that appeared in December was the sleep wake issue others have reported.  The first time this happened was during an 8 hour flight. I had shutdown my Surface as required by aviation restrictions and put it away in a neoprene sleeve.  After landing and removing it from the sleeve I found it on with the fans running at full bore and it was burning hot to the touch.  This has happened two other times since (the most recent yesterday but only for the 30 minute ride home from work.  I am worried that this may have damaged my Surface internals - things shouldn't run this hot.
    My battery life is now also terrible.  I used to use my Surface all day at work - now I have to leave it at my desk as after 3 embarrassing meetings where I had the battery suddenly cut out during a presentation it is just too risky (which had not been a problem prior to December).
    I was patiently waiting for the rumoured Jan 14th update - yet there has been nothing.
    One month now of what was an amazing device being useless for my main use cases - photo editing and presentations for work.
    What is also sad is that I have been a big fan of the Surface having 'sold' around 20 to friends and family - i.e. recommending they buy one.  Now though I cannot recommend it until the firmware issues are sorted.
    Does anyone know when the new patch will arrive to sort out these graphics and battery issues?
    Many thanks
    Andrew
