2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-15T18:54:22+00:00
    This may be a dumb question, but can you confirm how we can tell what updates are firmware related?
    2014-01-15T19:53:07+00:00
    I just got of the phone with Microsoft. They're sending out a replacement, but the agent said there's no way to request a new unit instead of a refurbished one. Fingers crossed.
    This is starting to sound like an old joke about soldiers during wartime.  The soldiers are told that there is good new and bad news.  The good news is that today they get to change underwear.  The bad news is "You change with you, you change with you ...".
